Fuel Rail Connection
Old Mar 8, 2006 | 11:44 AM
pcf_mark's Avatar
Default Fuel Rail Connection
I am working on an LS7 retro fit and the connection to the fuel rail baffles me. Other EFI engines I have worked on used a quick disconnect/dry break connection and you can use a specail Earl's or Russell fitting. This engine appears to have a hose clamp style connection. Please check the attached picture. You can see the green cap over the only open line in the fuel rail. Any have expeience with this?[IMG]C:\Documents and Settings\msnyder\Desktop\DSCF0056.jpg[/IMG]
I can't see to add an image - any pointers?
Old Mar 8, 2006 | 12:40 PM
Katech_Jason's Avatar
LS1TECH Sponsor
use the attachment option or host it somwhere and link it
Old Mar 8, 2006 | 02:18 PM
pcf_mark's Avatar
Fuel line connection
We will see if this works.
Old Mar 8, 2006 | 06:36 PM
John B's Avatar
Moderator
This uses the same fittings as adapting any LS1/2/6 fuel rail.
Old Mar 9, 2006 | 08:23 AM
UMIRacing's Avatar
Katech could set you up with a -6 AN adapter fitting
Old Mar 9, 2006 | 10:29 AM
pcf_mark's Avatar
My misunderstanding - I thought previous cars used a male coupler like line connection on the fuel rail. The fitting from Katech slides over the male fuel rail and somehow seals or grips the bulge in the steel tubing that is about 3/4" in from the end (see bulge above green cap in photo)?
Old Mar 9, 2006 | 11:26 AM
MadGoat's Avatar
I had mine cut and silver soldered.(sp)? an AN fitting on to the stock one. I believe Aeromotive sells one though.
