header ? for my Ls2
Old Mar 11, 2006 | 03:45 PM
Kounsy's Avatar
Old Mar 11, 2006 | 04:30 PM
Redneck Z's Avatar
Originally Posted by xphantomws6x
Well he might know if you told us some more info? Asking for a type of header while hiding your setup probably isn't the best idea if you want to get good answers.
Up until this post, it looked like you were going with a stock ci LS2 block, and LS6 heads ... in which case you would prob wanna stick with the 1 3/4" .... now if you're going with a 402ci LS2, with big heads and a big cam ... you'd want the 1 7/8".
See how that works?
Ditto that!
Old Mar 11, 2006 | 05:17 PM
Order 66's Avatar
For the love of god, Kooks does not make QTPs. Get your facts straight. I dont care what Kooks says, it aint true.
1 3/4 QTP HVMC is all you need. You dont need 1 7/8.
Old Mar 11, 2006 | 07:31 PM
LASTLS1's Avatar
6 Second Club Moderator
You get YOUR facts straight! I ordered a set from kooks and they came with "QTP" Tags on them in a kooks box!!!! I was pissed and called kooks and he told me that it was the same header, THEY MAKE THEM. The collector was a little longer on the "QTP" made by kooks! Any other questions? Also I ran a 1 7/8 to 2'' . On my 408 I made 528hp ran 10.30's on motor and low nines on spray. What kind of motor do you have to base your opinion off of?
Old Mar 12, 2006 | 09:53 AM
Kounsy's Avatar
I agree, i called TSP and he said that the 1 7/8 would be the best and yes I agree, what kind of motor to base that with?
Old Mar 12, 2006 | 10:17 AM
TPiS's Avatar
Tenured Member
Originally Posted by Kounsy
How do u know what kind of setup im going with, the only thing u know is a 402
I realize that all the info you gave was the cid. We build all size LS engines, In my opinion if it has a license plate on it regardless of cid a ! 3/4 primary will out perform a larger tube size. and extremly long primarys don't make power in the racing rpm range. I am going to attach a file of a independant test that was done by a GM engineer of our header vs LG long tubes. the base engine was a warmed over LS 2 making approx. 575 hp.
both these headers were 1 3/4 in.
myron c
Old Mar 12, 2006 | 10:30 AM
Kounsy's Avatar
Originally Posted by TPiS
I realize that all the info you gave was the cid. We build all size LS engines, In my opinion if it has a license plate on it regardless of cid a ! 3/4 primary will out perform a larger tube size. and extremly long primarys don't make power in the racing rpm range. I am going to attach a file of a independant test that was done by a GM engineer of our header vs LG long tubes. the base engine was a SCCA World challenge LS 2, These make approx. 575 hp.
myron c
Well its my bad on the lack of info starting this thread, Why does everyone with a 402 or bigger going with the 1 7/8 and not 3/4? I would see the 3/4 prob have more tq but the 7/8 would make more hp? I really just want the best performance for the strip. I appreciate everyone who has reply to this thread.
Old Mar 23, 2006 | 10:41 AM
Louis's Avatar
How radical of a 402? What weight? Auto or 6 speed?
Old Mar 23, 2006 | 12:48 PM
Wet 1's Avatar
I'd use 1 7/8" on anything more than a factory 402+ ci.
Old Mar 23, 2006 | 10:30 PM
Kounsy's Avatar
250/258 .614 .614 108 lsa, cnc ported ls6 heads, fast 90, 10.9.1 compression with a -14cc valve relief
Old Mar 28, 2006 | 11:06 PM
x phantom x's Avatar
STF veteran / 10 second club
myron c
I don't understand .... can you support your arguement that the 1 3/4 tubes will outperform the 1 7/8's? I'm not saying you're wrong, but I need a new set of headers for my 402 and I am trying to decide what I need as well.
Seems that everyone else I have talked to, including LG, seem to think that a 402ci = 1 7/8, end of story. You are the only person that thinks that is overkill, and I am interested to hear why.
Also, comparing LG's 1 3/4 to your 1 3/4 does not show us that 1 3/4 is better than 1 7/8 ....
Old Mar 29, 2006 | 09:21 AM
  #32
TPiS's Avatar
Tenured Member
The larger the tubes for a given engine the lazier it will be at the lower end of the rpm scale.say from an idle to 3500 rpm, This is on a light throttle roll on. The dynamics change at full throttle. so you need to determine if what you want is a dyno queen or a car that has crisp part throttle response.
The very best header would be a nascar style step with three merge collectors per bank. around $3500.00 for a set. I would be glad to have a phone discussion with you. to see what your combo needs.
952 448 6021 myron c
Old Mar 29, 2006 | 11:55 AM
  #33
WHY though. Do you have any graphs, track times, anything to prove what you claim? I would love to go by your word alone, but it seems like everyone else is on the other side of the fence. Not to mention, I have seen some nasty track times and dyno numbers from people with 402's who are running 1 7/8 ....
Old Mar 30, 2006 | 10:28 AM
  #34
TPiS's Avatar
Tenured Member
Default test results
To be honest with you it has been some time since I personally tested a set of 1 7/8 on a gen 3. maybe 1998. our specialtie is road racing were endurance is important. We were the top Corvette at this years Rolex 24 hr for instance. At this year Sebring race our motor set a new track record and sat on the pole. one of these were an LS-6 and the other a LS-2. both had 1 3/4 headers. I have attached a dyno sheet of a LS-2 based 427, 243 casting heads, 10.5 to 1 cr. pump 91 octane, our TPIS OVAL LS-6 intake, TPIS 1 3/4,
TPIS ZL-15 cam 236-241 .602 .567 on 112. This motor is for a STREET driven 4x4 auto. This same motor combo with with a larger cam will make over 665 hp.
MYRON C
Old Mar 30, 2006 | 06:01 PM
  #35
you forgot to attach the dyno sheets ... again.
Old Mar 30, 2006 | 06:35 PM
  #36
TPiS's Avatar
Tenured Member
I will try again in the morning. I thought it had uploaded.
mc
Old Mar 31, 2006 | 08:09 AM
  #37
TPiS's Avatar
Tenured Member
mc
if this doesn't work email me I know how to attach a file to a email
www.hpfarm@aol.com
Old Mar 31, 2006 | 08:23 AM
  #38
TPiS's Avatar
Tenured Member
www.hpfarm@aol.com
I got pro help from one of my younger employees. this should work
Old Apr 1, 2006 | 08:19 PM
  #39
TPiS's Avatar
Tenured Member
Could read the dyno sheet.
mc
Old Apr 2, 2006 | 01:38 AM
  #40
mc
If I can read this tiny thing correctly, it looks like an engine dyno sheet showing that you got a 427ci LS2 based motor to 610fwhp? Factor in 12-15% drivetrain loss, you're looking at 520-530rwhp on an M6 ..... That seems to be on the low side for a built 427. There are 402/408's making that power, and a handful of 427's in the 600+ rwhp range ...
