LS7 Clutch - What kind of power ?
Is there any reliable info on how much power the LS7 clutch can realistically handle ? Would this clutch be competition for something along the lines of a Spec Stg 3 or a similar clutch ... or no?
Considering the size difference (from what i've seen) in the LS2 and LS7 clutches and overall surface area, it should hold quite a bit of power for a stock clutch. I'd expect at least 600+ at the flywheel.
Yeah, a clutch holding on a dyno is one thing .... but slap some sticky tires on her, and that's a whole different ball game.
It would be awesome to have a clutch with a stock feel, that supported 600+ hp though.
anybody have any idea how long this clutch should last in the 500+rwhp power range?
I don't think it's a direct bolton...
Anyone can tell me parts and part# that I need to make it work ?
EDIT: Never mind - I think I found it... Supposed to be a $500 price for all
LS7 clutch/pressure plate assembly 24236500
LS7/LS2 flywheel 12571611
Slave/Throwout bearing 15046288
Flash-
Why do you say it is bad for you that the pedal is releasing higher? Someone else was saying that brand new it releases too low, so maybe as it breaks in it comes up alittle??
