Will LS7 intake bolt up to L92 heads?
Old Mar 22, 2006 | 10:33 PM
stang90gt50's Avatar
Default Will LS7 intake bolt up to L92 heads?
Is the Ls7 intake a direct fit for the L92 heads?
Could pick up a set of L92's for $400 or so, assemble them for another $300 plus or minus.
Then pick up a Ls7 intake cheap and not need any special rockers or parts for the heads. Could get it done cheap.
Old Mar 23, 2006 | 02:32 AM
StreetnStrip's Avatar
Closed ex-Sponsor Account
no it will not work ur better off getting a sheet metal one made or do like Im going to do and that is to modify the Edlebrock carb style intake.
Old Mar 23, 2006 | 08:30 AM
Stang's Bane's Avatar
Would this fit under the cowl of a F-body? You are planning on converting it to EFI correct?
Old Mar 23, 2006 | 10:43 AM
MrDude_1's Avatar
NO.
you still need the "special" rockers and parts for the heads.
you SHOULD still measure your required pushrod length too..
Old Mar 23, 2006 | 10:44 AM
MrDude_1's Avatar
if its custom made, you could make it fit in anything.
