LS7 with LS1 reluctor wheel?
Old Mar 26, 2006 | 01:50 PM
NemeSS's Avatar
Question LS7 crank with LS1 reluctor wheel?
i beleive i saw a post here about a member here that pressed a LS1
reluctor wheel to his LS7 crate engine stock crankshaft and
this was last year when i think he was one of the first to get one
he had pics of the dissasembly and evrything
i have recently gotten ahold of one the LS7 crank from a source
and i want to make it work in a LQ9 block
and fire it with a LS1 pcm,hptuners, etc.
precciate any info or if any can direct me to the thread
Old Mar 26, 2006 | 02:02 PM
Katech_Jason's Avatar
LS1TECH Sponsor
We have pressed a LS1 trigger on an LS7 crank. We have a jig to align it correctly.
Old Mar 26, 2006 | 02:23 PM
NemeSS's Avatar
i have presseda reluctor ring to a stock crank before, so i know the procedure
is ther anything different in i should do different compared to a stock
crank?
i also own the Goodson tool to install the reluctor to the crank
thanx for the input
Old Mar 26, 2006 | 03:47 PM
98blackSS's Avatar
That was me. We used the goodson tool as well so you should be good to go..
Old Mar 26, 2006 | 05:20 PM
Bill Reid's Avatar
Going with dry sump?
Old Mar 26, 2006 | 07:11 PM
Steve Bryant's Avatar
LS1 Tech Veteran
What about the longer snout on the LS7 crank? Doesn't that cause a problem on an engine without the dry sump setup?
Also, since the bobweights for the LS7 are setup for the lightweight titanium rods, will you have to add mallory metal to balance with regular rods and pistons?
Steve
Old Mar 27, 2006 | 06:59 AM
LS7Engineer's Avatar
good point, the LS-7 crank is balanced for LS-7 components. Would need to re-balance to the new bobweight.
Old Mar 27, 2006 | 11:45 AM
NemeSS's Avatar
crank is going to get rebalanced with/for h-beam rods and JE pistons
6 in. steel H-beams,clevite H series bearings
1.245 c.h. 12cc spherical dish slugs 4 in bore
balanced with mallory metal
i will be doing the crank balancing in the auto machine shop
i work in,hope i dont run into too many probs.
man i really just want to go with conventional oiling
since i am using standard tension rings
Old Mar 27, 2006 | 10:38 PM
let me know if you have any problems balancing I might be able to help
Old Mar 28, 2006 | 07:18 AM
Quick Carl's Avatar
What are you going to do with the LS7 reluctor wheel ? We are waiting on one from GM for a project. We do have new LS1 reluctor wheels in stock if you need one.
Does anyone know for sure that the Goodson tool also works on the LS7 reluctor wheel ?
Old Mar 28, 2006 | 07:22 AM
98blackSS's Avatar
We checked the alignment of the 58x wheel before we pulled it - just to check the tool since it was new. It was dead on.
Old Mar 30, 2006 | 01:50 PM
Quick Carl's Avatar
Thanks for the information. Now I need to find a LS7 reluctor wheel.
