Factory LS7 valve spring specs?
BTW, we have a set of LS7 take off springs, seals, retainers and locks from our crate motor if anyone is interested in them
These springs have some run time on them and therefore may be a few pounds off of new springs. The stock springs are a conical dual diameter design like all other LSx springs. The retainers are steel.
Installed height = 1.995"-2.00" (without seal/spring base).
Spring base thickness = .048"
Net installed height = 1.952"
Seat pressure = 113.0lbs
Open pressure = 312.4lbs @1.352" (.590" lift)
Open pressure = 316.6lbs @1.342" (.600" lift)
Coil bind = 1.304" (.644" lift)
Hope this helps.
Richard
