Stock L92 Head Flow Data
Old Apr 7, 2006 | 09:39 AM
Greg Fell's Avatar
I believe they are the same rockers
Old Apr 7, 2006 | 11:25 AM
NO-OPTION-2002's Avatar
They're not.
L92 = #10214664 int. #12569167 exh. 1.7:1 ratio
LS7 = #12579615 int. #12579617 exh. 1.8:1 ratio
Hope this help with some of the confusion.
Old Apr 7, 2006 | 12:20 PM
MrDude_1's Avatar
Originally Posted by NO-OPTION-2002
They're not.
thanks for the part numbers.
what are the odds of someone posting up a pic of the GM diagram, and a list of all the parts needed for the swap.....?
btw, im going to stick with the 1.7 ratio if i can... 1.8s are nice, but the agressive lobes i will eventually put in there wernt designed to move the valve that fast.. they were made for the 1.7s.. and pushing that hard. lol.
Old Apr 7, 2006 | 12:49 PM
Nate_Taufer's Avatar
Originally Posted by MrDude_1
could you elaborate?
why wont the L92 valvetrain work with L92 heads on a diffrent shortblock??
The L-92 rockers and LS7 rockers are pretty much identical except for the 1.8 versus 1.7 rocker ratio. They're both offset rockers for the huge intake port. The L92 valvetrain will work just fine. I just figure if Im getting the same priced rockers I might as well splurge for a higher ratio at the time.
And FWIW, if shimmed correctly there's not any adverse affects on your springs going from 1.7 to 1.8 rocker ratio.
Nate
Old Apr 7, 2006 | 01:08 PM
MrDude_1's Avatar
Nate
meh, it effects the lift, and how fast the valve moves... really, i think the aggressive profiles offered today (basically pro-stock lobes.. lol) are enough... i want to daily drive her for atleast a year before i have to change springs...
but thats off the subject... getting back on track, whos going to be the first one to have this on a running performance app??? i know im not.. its a side project with 2 other car projects going on.. so it'll be awhile.. lol.
Old Apr 7, 2006 | 03:50 PM
NemeSS's Avatar
were the valves used to flow the head stock parts? 2.16/1.59
also what is the part number if they are?
need part #'s asap
Old Apr 7, 2006 | 08:49 PM
Originally Posted by Richard@WCCH
I just finished flow testing a new stock L92 head. All I can says is…….WOW! What a nice part.
Valve dimensions:
Intake = 2.160” X 4.870” X .314”(8mm)
Exhaust = 1.590” X 4.920” X .314”(8mm)
Seat/throat diameters:
Intake = 1.870”
Exhaust = 1.355”
Richard
Yes the valves are 2.16" and 1.59"
Nate
Old Apr 8, 2006 | 01:59 AM
Bring the Noise's Avatar
You could probably use either Comp Cam's Pro Magnum Roller Rockers or Crane Cam's Gold Series (as neither are shaft mounted).
Basicly the 1.7 or 1.8 sets should work with a new guide plate (due to the offset valves). The studs, locks, and rockers would be used though.... just new guide plates.
Old Apr 8, 2006 | 02:08 AM
Are they both offset rockers?
Nate
Old Apr 8, 2006 | 04:09 AM
SuperSporttruck's Avatar
Does anyone know if the pushrod length is the same as LS7 and if so, what is it.
Old Apr 9, 2006 | 09:37 AM
383ss's Avatar
these are an awesome set of heads, especially for stock!!
anyone else confused about the 260cc runner volume?? why is it so large? aren't these on about ~370cid stock? considering its going in a 5000lb SUV wouldn't you want smaller runners to help with tq?
Old Apr 10, 2006 | 09:07 AM
  #32
MrDude_1's Avatar
because the goal isnt high velocity..the goal is just "let as much air as possible into the motor, as easily as possible"..
seriously though, just because the intake port is huge, doesnt mean it has to suck down low.. im sure ALOT of R&D has gone into the design of this port.
Old Apr 10, 2006 | 01:50 PM
  #33
NemeSS's Avatar
p/n for the valves used tp flow the heads
plz
Old Apr 11, 2006 | 09:39 PM
  #34
ChucksZ06's Avatar
Does anyone have part numbers for the valves? will ls1 rockers work on the exhausts? I know the intakes are the offset rockers...part numbers for rockers? Thanks.
Old Apr 12, 2006 | 03:14 AM
  #35
StreetnStrip's Avatar
Closed ex-Sponsor Account
I have them ill psot them up later today
Old Apr 12, 2006 | 08:26 AM
  #36
383ss's Avatar
hmm. then why is it beat into our heads by AFR and others that small well flowing chambers are the way to go for best hp/tq
Old Apr 12, 2006 | 08:33 AM
  #37
Greg Fell's Avatar
Velocity is great. But, the bottom line is, you still need air. In other words, if you only had wicked port velocity, but only 150 cfm, you'd make great tq and such, but a 500 cfm head that has lower velocity would crush it up top.
Old Apr 12, 2006 | 08:54 AM
  #38
383ss's Avatar
I understand that, but for a stock motor you need that kind of flow and 260cc runners?? I don't get it. I serioulsy doubt GM is looking for killer 'up top' numbers for an escalade.
hell, ETP recommends 240cc heads for 408's unless they are race motors then the 255cc head. AFR's 205 is enough to feed 500rwhp. 260 to 205 is a HUGE difference, IMO.
Old Apr 12, 2006 | 02:03 PM
  #39
Wnts2Go10O's Avatar
its how they make everything in the new motor work together. granted there used to be a time where bigger meant better and its past, but now adays it seems theyve found a way to keep low end up even with the bigger heads. if youve noticed how LSx torque curves look, they peak early but have a great average across the board. i would ventur to bet that torque on these heads would peak at 4500-5000 on a smaller 6L motor BUT would have a great average across the board. remember the engineers are the ones tht still know wht theyre doing, its the execs that are morons
Old Apr 12, 2006 | 02:04 PM
  #40
MrDude_1's Avatar
like alot of things the answer is some marketing, some truth..
think about this:
for decades guys have been hogging out intake runners... with a large cam, large displacement, you make large peak numbers.. great for racing.
but on the street, you end up with the usual drives shitty drag car. the "area under the curve" drops waaay down when you're not using that big port.
so AFR and other cyl head guys work their best to make a large flowing head, that also has enough velocity to work on lesser flowing motors... like everything, its a compromise.. and for 90% of the market, it works better..
CC is a ok way to compare ports in the same way that PSI is a OK way to compare boost.... in other words, its somewhat related, but really doesnt mean squat. lol.
think about the millions in R&D work GM put into the LS7 head program.. they're using what they learned there on their massed produced cars.. the less intake restriction, the better. and with this new cyl deactivation routine, these engines will be seeing double the airflow in each cyl. GM figured out a way to make these heads flow alot and work well thru alot of R&D.
companies like ETP and AFR are somewhat limited in that they have to remain close to "stock ports".. otherwise, headers, intakes, ect would come into play, and you'd end up spending waaay too much for those heads to work for you. so even if they know widening the port, doing xyz makes the head flow better, they cant do it. GM did not have this limitation.
really, these heads probably arnt going to be best for everyone.. but for the engine im trying to build, i believe it will work great. im also not expecting an ideal street car. lol.
