Introducing Katech's new crate engine packages
Old Apr 14, 2006 | 01:36 PM
Dave F's Avatar
I used to be a big fan of Katech (built my past 3 WC engines), but they don't seem to want the business of the little guys anymore. The doubled the prices on my last engine build, and were over a month late in getting it to me.
Obviously a reputable company IF you've got unlimited TIME and MONEY!
Old Apr 14, 2006 | 01:54 PM
Solid346's Avatar
tooo much, that we cant afford !!!
Old Apr 14, 2006 | 03:43 PM
ramairws6's Avatar
Ouch!!! Crazy prices to say the least!!Traver
Old Apr 14, 2006 | 05:01 PM
H8 LUZN's Avatar
yup, there is a point of diminishing returns on engine builds... they have exceeded 99.9% of the typical weekend racers needs with a price tag that exceeds 99.9% of the typical weekend racers budget
kinda like a ferrari.. you get slightly better designs for ALOT more $$
Old Apr 14, 2006 | 11:54 PM
dnm12's Avatar
yeah a total bummer when I first posted I thought I was gonna get blasted but what in the heck is $22,000 about? seriously if you have to ask you can't afford it, and to think what I could do with $22,000 from the ground up or with nothing is absolutly scary 600-700hp would be the start try 1000-1200 horses or more!!!!!!! But once again all in IMO
Old Apr 15, 2006 | 07:19 AM
FunkyTownFBody's Avatar
5th gear @ 7800rpm wit 4.10 gears : 199mph
Old Apr 15, 2006 | 09:56 AM
gollum's Avatar
Katech,
Would it be possible or wise to build a LS1 402 (4.00"bore x 4.00"stroke) using the shorter 6.064 LS7 titanium rod. I know a down sized version of the LS7 piston would be needed to fit the smaller 4.00" bore but would it clear the LS1's reluctor wheel?
I was also thinking of using stock LS1 rods with the above mentioned 402 and keeping engine revs under 6200 rpm. Is the rod strong enough and where can I get custom pistons for this project?
Old Apr 15, 2006 | 12:15 PM
chuntington101's Avatar
do the engines come complete and ready to run?? or are there other bits needed? if so what like??
Also do they come with ECUs???
thanks Chris.
PS some very nice engines in that line up!
Old Apr 15, 2006 | 05:43 PM
Katech_Jason's Avatar
LS1TECH Sponsor
thanks Chris.
The engines come as they do from GMPP in regards to what comes with them. No front drive, harness, PCM etc.. We can quote and supply all those items for you.
Old Apr 16, 2006 | 12:29 PM
Dune-LS1's Avatar
Great products and a good price. And the people who are bitching about the price don't have a clue what the parts cost that go into these engines... You get what you pay for!
Old Apr 16, 2006 | 04:01 PM
ramairws6's Avatar
That's absolutely false! I'm in the process of building a 427 right now and each of these parts individuley has been priced.I'm not bitching about the price....I am just stating that for money there could be alot more to be had if you took the time to do most of it yourself. I think alot of their pricing is based on their name and reputation and that does go a long way. Let's wait and see what the shortblock price is and I will then decide if they are even in the ballpark for the average blue collar guy out there. Traver
Old Apr 16, 2006 | 04:05 PM
  #32
LS1TECH Sponsor
There's the key word. Our engine builders have a minimum of 8 years of race engine building experience. Most have 20-30 years. You can do anything yourself cheaper, whether it's building an addition on your home or building a race engine. When you want to pay for the expertise, you hire the professionals.
Old Apr 16, 2006 | 04:09 PM
  #33
OmniRex's Avatar
If they want to price themselves out of competition then I guess thats their problem.
Old Apr 16, 2006 | 04:14 PM
  #34
OmniRex's Avatar
Features a Warhawk aluminum block,Mahle/Manley forged aluminum pistons (11.4:1 compression ratio),Total Seal piston rings,Eagle 4340 forged crank,Eagle 6.125”long forged steel rods with L19 bolts.101260 438 c.i.d.LS1 Low Comp.S.B.Assy for 15° valve angle $6,895.99101262 438 c.i.d.LS7 Low Comp.S.B.Assy for 12° valve angle $6,895.99101264 454 c.i.d.LS1 Low Comp.S.B.Assy for 15° valve angle $6,995.99101266 454 c.i.d.LS7 Low Comp.S.B.Assy for 12° valve angle $6,995.99101268 481 c.i.d.LS1 Low Comp.S.B.Assy for 15° valve angle $7,495.99101270 481 c.i.d.LS7 Low Comp.S.B.Assy for 12° valve angle
these shortblock prices seem more inline
Old Apr 16, 2006 | 05:41 PM
  #35
ramairws6's Avatar
Jason I agree with you 100%.Knowledge and great expertise is a must it just sometimes comes with a huge $$!! Traver
Old Apr 16, 2006 | 05:51 PM
  #36
Dune-LS1's Avatar
"Eagle" rod and crank in a $4000.00 block.
Old Apr 17, 2006 | 07:10 AM
  #37
David Gordon's Avatar
Those prices seem very high to me. Are these just regular stroker engine like the other sponsers carry or are they some type of all out racing engines the pros use?
Old Apr 17, 2006 | 07:31 AM
  #38
Wet 1's Avatar
While I wouldn't use those pieces either for my own build, I don't see why they wouldn't work. Have you ever heard of someone breaking an Eagle rod/crank??? Although Eagle's stuff is cheap, their parts are tough and made to handle big power.
Old Apr 17, 2006 | 08:37 AM
  #39
org's Avatar
org
It all depends on what you're going to be using it for. $25000 for a race engine being used primarily for racing is reasonable, IMHO. $25000 for a hobby engine being mostly driven on the street is a waste of money. There's no point in having an engine that will stand the rigors of all out road racing when you'll be driving it to work and occasionally standing on it for a mile or two.
Obviously, these prices are being set based on what the market will bear, not necessarily the cost of the build. As long as there are enough customers willing to pay the price, it will remain high and probably get higher until market forces change. Since there are lots of other quality builders that have a good product at better prices, it's not all that important.
Old Apr 17, 2006 | 10:56 AM
  #40
firefighter's Avatar
There is ALOT to be said about the advantage that comes with experience.
Also you need to buy the proper tool for the job do not be scared by the price of race engines unless you are a racer look to what is for the street motors.
Remember you don't use a sledge hammer to tap in a penny nail.
