Introducing Katech's new crate engine packages
Old May 13, 2006 | 09:27 AM
  #61
AU N EGL's Avatar
Originally Posted by Katech
The first set of cases are back from vacuum impreg
Old May 13, 2006 | 10:13 AM
  #62
Katech_Jason's Avatar
LS1TECH Sponsor
Originally Posted by AU N EGL
All of our sleeved cases are double vacuum impregnated. The process is done 2x to greatly reduce porosity.
Here's a good explanation:
Vacuum Impregnation is an advanced modern porosity sealing technique. The process effectively tests and seals leaks in castings. By sealing porosity, impregnation can also extend machining tool life, particularly in powder metal parts.
The procedure is used for sealing microporosity in metal castings, powder metal parts, electronic components, plastic composites, and other porous substrates. A special advanced technology sealant fixes the leaks and seals the internal porosity.
Old May 13, 2006 | 01:07 PM
  #63
AU N EGL's Avatar
thanks Jason. I though it might be something to that effect.
Old May 13, 2006 | 07:33 PM
  #64
Quickin's Avatar
Don't count on it right away. We should be getting rods sometime in June. Like World Product's problems with the Warhawk, it always takes longer than you think it will when dealing with outside sources. I will post as information becomes available.
Bore 4.125
Stroke 4.000
Nothing will be "lacking", it's we've just selected some good parts at a reasonable price.
So it'll be able to take a good blast of spray like a 250 progressive shot.
Also, which block will you be using for the 4.125 bore?
Old May 13, 2006 | 07:37 PM
  #65
LS1TECH Sponsor
I'll let you know once we finalize a piston choice.
It will be a Katech sleeved LS2.
Old May 23, 2006 | 03:56 PM
  #66
MrDude_1's Avatar
ttt for budget 427 price....
Old May 23, 2006 | 04:01 PM
  #67
LS1TECH Sponsor
We're going to build the first few before announcing the price. I don't want to excite or dissapoint.
Old May 23, 2006 | 04:09 PM
  #68
Quickin's Avatar
I don't want to excite .
Too late
Old May 23, 2006 | 04:26 PM
  #69
mongse's Avatar
I ruin the end of films...
KAT-A4720 Crate Engine - Warhawk 7.4L
The biggest displacement crate engine offered by Katech Performance. Package includes a Warhawk 7.4L (454ci) block, Warhawk LS7X heads outfitted with LS7 valvetrain, forged crankshaft, and Katech forged piston-rod assembly.
Pricing and power levels pending Warhawk availability and testing
Interesting...
Old Jun 4, 2006 | 12:24 PM
  #70
Speedpup's Avatar
Originally Posted by Dune-LS1
"Eagle" rod and crank in a $4000.00 block.
yea more crap from CHINA
Old Jun 16, 2006 | 07:11 AM
  #71
chuntington101's Avatar
any news???
Chris
Old Jun 17, 2006 | 10:25 AM
  #72
96-speed's Avatar
on,
Couple of thoughts...
What exactly does "balanced and blueprinted" mean? I've heard this term for years and years, and never really thought twice about it. Balancing a rotating assembly, sure, makes sense. Blue printed? Please explain what these two terms mean to a Katech customer.
Quote:
Originally Posted by Karlo
"KAT-A4685 Reb Crate Engine - Rebuild ASA Late Model
Have Katech Performance service an existing Fast Burn ASA Late Model engine. Rebuild includes complete teardown and inspection, new main and rod bearings, new gaskets, any other required parts and dyno validation.
$3500 400hp"
$3500 for new bearings, gaskets, and there will be basically no machine work invloved? That sounds pretty steep, IMO. Granted, there is plenty of overhead that you guys are faced with (nice shop pics, btw), but this doesn't seem like a very intensive job - basic rebuild (emphasis on RE-build). Maybe there is more to this rebuild, but am I way off base for expecting something 2k cheaper? With that in mind, people buying from Katech probably want someone overqualified to do the job and will gladly pay those prices. From the sounds off it, you guys have a specific niche in the market, just like MTI does nowadays (driveout packages). With that in mind, disregard this second questions and just answer the first, please .
Hopefully this doesn't come off as an attack - just a observation/question.
Ryan
__________________
Old Jun 17, 2006 | 10:46 AM
  #73
LS1TECH Sponsor
Originally Posted by chuntington101
any news???
Chris
Waiting on rods. Taking a little longer than scheduled.
Old Jun 18, 2006 | 04:09 PM
  #74
Nabbs's Avatar
KAT-A4730 Crate Engine - Street Attack LS7 7.0L
Top-tier LS7 performance engineered for street applications. Crate engine features Katech 11:1 compression forged pistons, solid small-end rod bushings, street-optimized camshaft, and valvetrain enhancements. F-Car and Y-Car applications available. The perfect choice for high power, daily driven vehicles.
Starting at $8,400 + LS7
630+hp
KAT-A4735 Crate Engine - Track Attack LS7 7.0L
The ultimate normally-aspirated LS7 crate engine for off-road / track use applications. Drawing from over two decades of experience with championship winning pushrod V8s, this package is race ready. Features Katech 12:1 or 14:1 compression forged pistons, solid small-end rod bushings, high output camshaft and valvetrain enhancements. Available with electronic or mechanical throttle control.
Starting at $8,400 plus LS7
650+hp
KAT-A4740 Crate Engine - Air Attack LS7 7.0L
Extreme forced induction performance for the LS7 engine. This package includes Katech forged low-compression pistons, forged steel connecting rods, upgraded camshaft, and upgraded valvetrain.
HP levels vary
Jason -- For the above packages I assume you meed a complete LS7 as opposed to just the block and heads? Could one have an LS7 block and heads dropshipped to you guys and have you assemble it with all the goodies (minus intake, accs, etc)?
Why not do a budget 427 based on the LS7 block? Has to be a ton less machine work on a block that does not require sleeves.
Thanks,
-N
Old Jun 18, 2006 | 05:16 PM
  #75
LS1TECH Sponsor
Thanks,
-N
-How are we going to run it on the dyno?
-Our budget sleeved LS2 (without Katech main caps), TBA soon, will be cheaper than the LS7 block.
Old Jun 18, 2006 | 06:23 PM
  #76
Nabbs's Avatar
I'm not sure I understand your question. I was asking specifically if your LS7 packages are meant for those who primarily have full LS7s ie a C6 Z06, or if they are meant for those of us who would be willing to supply a block and heads only.
Old Jun 18, 2006 | 06:45 PM
  #77
LS1TECH Sponsor
Yea we could do that.
Old Jul 2, 2006 | 11:31 PM
  #78
VictionOne's Avatar
Any updates on the 427 block?
Old Jul 3, 2006 | 05:32 AM
  #79
LS1TECH Sponsor
Rods were a little delayed. We just got them. We are going to finalize some details and start assembling.
Old Jul 3, 2006 | 06:20 AM
  #80
98blackSS's Avatar
oops, didn't see J's response.. Can't wait to hear the word. Going to start tearing the car down now for a serious makeover.
