LS7 fuel pump
Old Apr 20, 2006 | 07:30 PM
Phillipm's Avatar
Default LS7 fuel pump
We are currently putting an LS7 in a 69 Camaro. We will probably order a Rick's fuel tank. Can anyone suggest a fuel pump?? Other than a ASA cam the motor is basicaly stock w/ forged pistons. -Phillip
Old Apr 21, 2006 | 07:26 AM
pcf_mark's Avatar
I am using a 55 gph/255lph in tank pump. Not running yet but is should support up to 600HP naturalyl asprited at 60 psi.
ASA cam? What did you need to change to add that? Springs, retainers etc?
Old Apr 21, 2006 | 12:26 PM
Phillipm's Avatar
Do you know what brand pump that is??
It was recommended to run this cam by Katech. They didn't say anything about springs or retainers. The stock cam actually has a higher lift than the ASA cam (I believe) but is much less aggressive on overlap and duration.
