Stroke Rod length questions
Old Apr 24, 2006 | 10:37 PM
RedHatRdRacer's Avatar
Default Stroke Rod length questions
So I was wondering If i have a 6.0 block a 4.1 crank, 6.125 rod and a 4.030 piston... also same crank and rod, with a 4.00 piston
thanks in advance
Old Apr 25, 2006 | 05:27 AM
Randy WS6's Avatar
I have a LS2 6.0 block with 4.100 crank & 6.125 rods & 4.030 bore makes 418cid ,I beleave with just a 4.00 bore but with the same crank & rods it would be a 414cid.
And for nitrous i run a pro fogger 250 shot, if i run some body and they dont have nitrous or a super charger or turbo i wont use my nitrous but if they do, ill pore it to it.
Old Apr 25, 2006 | 10:11 AM
KCS's Avatar
KCS
Moderator
thanks in advance
Depends. As long as the compression heights of the pistons are the same and the deck height of the blocks are the same, it'll be just fine. If anythings different, you may have problems.
