How much power will I make?
-Warhawk block (tall deck)
-11:1 CR or so (limited to 91 octane)
-4.250" callies magnum xl crank (making 454ci)
-Manley I beam rods
-ET performance c5r heads (flow in the 370cfm range at .650 lift.)
-cam duration around 250 - 260
-Sheetmetal intake (by the way, who do you guys recomend for sheet metal intakes? I would liket to get a sweet intake for under 2k if possible.)
-Probably run it to 7k rpm's
Im also considering running ET's ls7 heads and a ls7 intake. Might not make quite as much power, but would save me some $.
