408 clearance problem
Old May 3, 2006 | 06:07 PM
Badls6SS's Avatar
Default 408 clearance problem
Has anyone that has built a 408 ran into this my #1 connecting rod bolt is hitting the oil pan. Anyone else come accross this?????
Eagle 4.00" crank
Eagle 6.125" rods with arp bolts
Diamond 4.030" pistons
Old May 3, 2006 | 06:09 PM
Ryne @ CMS's Avatar
LS1TECH Sponsor
mine cleared no problem, no grinding, but i am running callies rods, maybe its a eagle issue.
Old May 3, 2006 | 07:22 PM
DrkPhx's Avatar
Eagle 4.00" crank
Are you it's not the rod bolt scraping against the windage tray? You're supposed to shim the windage tray for clearance.
Old May 3, 2006 | 08:01 PM
Nate_Taufer's Avatar
It's probably hitting the windage tray. Just space it out with some washers.
Nate
Old May 3, 2006 | 10:21 PM
Badls6SS's Avatar
NO!!!!!! i shimmed the tray this is hitting the oil pan the tray on the F body only goes from the #3-#8 cylinders #s 1 and 2 don't hit the windage tray.
I have heard that callies and lunati rods don't have a problem. I want to hear from anyone else w/ eagle rods w/ a 408
Old May 4, 2006 | 11:24 AM
1QWIKZ's Avatar
my buddy used eagle rods and arp bolts..no problems during the build up.
Old May 4, 2006 | 12:47 PM
matt346ls1's Avatar
Mine hit bad, I have aluminum rods though. I cut a hole about 2" by 1" where the problem area is and welded a plate to the bottom. problem fixed.
Matt
Old May 6, 2006 | 09:31 AM
ta40k's Avatar
Hey, I had the same problem, just barely hit, clearanced itself out, about .05 inch groove in my pan now, didn't catch it till I took it apart after a nitrous boom!
 Michael S. Palmer
Old May 6, 2006 | 02:42 PM
Randy WS6's Avatar
I had the same problem with my 4.100 eagle crank & 6.125 rods, cut a gruve in the pan to clear the rod bolt
Old May 7, 2006 | 07:13 PM
Badls6SS's Avatar
yea I had to grind the oil pan to get it to fit. As i was doing that it got to thin around the groove that was in the stock pan so i sent it out and had the pan reinforced around that area by welding it and regrinding it
Old May 8, 2006 | 11:05 PM
racer7088's Avatar
Yes on some you have to grind the pan every once in a while but not always and this goes for all strokers as well.
