ls2 402
Old May 16, 2006 | 03:05 AM
dropped_ls1's Avatar
Default ls2 402
i am about to build my motor finally. it is going in a 99 ss. the motor is going to consist of a LME ls2 402 with ls6 heads from et performance. (2.08-1.55) valves. and probley a fast 90mm intake. it will be in a m6 with about 11.2-1 compression.
who does some bad *** custom cams for a set up like this. it will be sprayed some about a 150 to a 200 shot. also what kind of power do yall think something like this would put down on motor and on gas.
on the cam thing i want it to be hydrolic still and a little streetable. i only drive it about 3-4 times a monthbut when i do its about 150 miles at a time. the cam that is in it right now i think is 601-604 on 234-236 112. i think that is real close.
