6.0 Vortec to 5 speed Trans
Old May 16, 2006 | 08:14 PM
Randy_M's Avatar
Default 6.0 Vortec to 5 speed Trans
I want to install a 2005 6.0 LQ4 Vortec in a '90 model GMC Sierra SLE 1500 that currently has a 350 Gen I with a factory 5 speed manual OD transmission. Can I use the earlier '90 flywheel, hydraulic clutch and transmission with this engine? I understand there is a flex plate adapter that is necessary if you want an earlier automatic with the newer flexplate but I can't seem to find any information on the swap I want to make. Any help would be appreciated.
