LS7 crank // LS1 flywheel ?
Old May 19, 2006 | 06:45 AM
matt346ls1's Avatar
Default LS7 crank // LS1 flywheel ?
Will the LS1 flywheel bolt right on to an LS7 crank, I was assuming so but want to be sure.
Matt
Old May 19, 2006 | 07:30 AM
Katech_Jason's Avatar
LS1TECH Sponsor
Matt
Yes
The pilot bearing will have to be changed though if you're using a T56.
Old May 19, 2006 | 08:05 AM
matt346ls1's Avatar
Originally Posted by Katech
Yes
T56 lol. What pilot bearing is in that crank though?
Old May 19, 2006 | 10:43 AM
LS1TECH Sponsor
I meant F-body T56. There is a larger pilot bearing in there from the factory.
Old May 19, 2006 | 10:51 AM
matt346ls1's Avatar
I have a Liberty 5 speed but I use the factory f-body pilot bearing. The LS7 one has to be changed I take it. Will the f-body one slide right in?
Matt
