what is needed to fit LS7 topend in LS1 camaro?
Old Jun 14, 2006 | 11:14 PM
Abdullah's Avatar
Default what is needed to fit LS7 topend in LS1 camaro?
what is exactly needed to fit LS7 topend of course with required bore 4.125" in a LS1 camaro? in case of fuel rails, using LS1 harness and PCM, UMI TB,...etc?
btw, the UMI throttle body will solve the throttle cable problem in the LS1 camaros to fit LS7 intake, right?
i want to use the 9.24" deck 4.125" bore warhawk block. the warhawk block is LS1 style, correct?
thanks.
