Ls7 on ls6
Old Jun 26, 2006 | 08:46 PM
bandit01ws6's Avatar
Default Ls7 on ls6
What will make the swap? I know the ls6 heads are the same as ls2 so im wondering if the ls7 heads will bolt up to an ls6 block? If so would i see a significant gain or should i just buy some aftermarket heads and intake?
Old Jun 26, 2006 | 09:02 PM
Katech_Jason's Avatar
LS1TECH Sponsor
Yes they will bolt on (in the most literal sense). The valve angle is 12* and they have 2.200 intake valves. They will not clear a stock bore and you'll need deeper valve pockets. You're probably better off with a ported LS6 head. Give me a call...I've got a set at a fraction of the cost of a complete LS7 head.
Old Jun 26, 2006 | 10:50 PM
Haans249's Avatar
I would go with what he suggested
