402 Piston Question
Old Jun 28, 2006 | 07:33 PM
SinCity-Z's Avatar
Default 402 Piston Question
Guys,
I am getting ready to start my 402 stroker project and I have a couple of questions I need help with.
What Piston / head combo are you guys using? I can't seem to find a Flattop Mahle Piston with a -2cc valve relief. I would be topping them off with AFR225's with a 72cc chamber and a 0.040" cometic gasket for a static comp ratio of 11.0:1. I didn't want to use -12cc the dished piston with the 62cc chamber heads. Also, any foreseen problems with Piston to valve clearance?
Monty
Old Jun 28, 2006 | 07:41 PM
Demon SS's Avatar
Diamond makes a -2cc piston for this application, if that helps any. there should be no p/v issues with your setup, the valve reliefs give an extra approx .100 clearance
Old Jun 28, 2006 | 07:50 PM
SinCity-Z's Avatar
Thanks for the quick reply Damon. How do the Diamonds compare to the Mahle?
Old Jun 28, 2006 | 08:07 PM
Demon SS's Avatar
Diamond is typically a better grade material (2618 alloy) and usually considered an upgrade from the Mahle shelf pistons.
Old Jun 28, 2006 | 08:11 PM
SinCity-Z's Avatar
Thanks Scott!
Old Jun 28, 2006 | 10:58 PM
GFORCE1320's Avatar
JE just came out with a 5cc flat top. I got mine from Summit for like $689. or so.
I'm using 62cc Darts, put me right at 12-1.
