would it fit?
Old Jul 14, 2006 | 02:39 AM
SoCalZ28's Avatar
Default would it fit?
would a LS6 fit/bolt in a stock k member 99 Z28 camaro?
Old Jul 14, 2006 | 03:13 AM
Bring the Noise's Avatar
Swap the Pan for the Fbody pan and it should.
Old Jul 14, 2006 | 12:38 PM
Beast96Z's Avatar
Yes, many of the 01' and 02' F-bodies came with LS6 blocks, so placement and bolting in isn't an issue. Depending on if it is a crate motor or just a long block, some things like accesories and deffinatlly the oil pan need to be swapped. If it's just the long block, just swap pans and go.
Old Jul 14, 2006 | 01:53 PM
SoCalZ28's Avatar
Sweet, Thanks!!!
