TEA stage 3 AFRs on a LS2 402
I don't know a lot about building engines. That's why I'm having someone very reputable build the car for me.
Mike
Very nice numbers. I only hope I can get close to that. What cam are you running? Are you also using the Fast 90/90? I'll be using the LS6 w/ ported throttle body for a while until I can afford something better. I've also been thinking about running an LS2 intake with a 90mm TB. Wouldn't that be similar the the Fast 90/90?
TEA does a killer job with their port work... for the money I dont see why you wouldnt go with a ported head instead out of the box. It was about $500 more than a stock pair of afr 225's..and worth every penny.
For the money TEA Stg 3 darts will make just as much power just on a different casting. Its the same port design, flows as well and costs ALOT less...thats probably your best deal for the money on a radical head like that.
That makes me feel better about dropping that much coin for a set then. I figured I'd do the engine right the first time and not worry about changing set-ups later.
I guess I'll be happy with everything if I can run low 11s on motor. Think that's possible with that motor? One of my buddies said I will probably be in the 10s with some good traction.
https://ls1tech.com/forums/showthrea...hlight=program
