Wideband Bung position?
Old Aug 10, 2006 | 12:48 PM
PREDATOR-Z's Avatar
Default Wideband Bung position?
Hello everyone
Where is the best place to put the wideband O2 bung?
I'm switching to LTs and a custom ORY (from MACs and Y with Magnaflow cats)
Right now I have it in the merge Y pipe, is there a better place for a better reading?
Thanks,
Mark
Old Aug 10, 2006 | 07:31 PM
My90Iroc's Avatar
I know myself along with a few other people around here have them in the merge collectors. Seems to make sense there and it's pretty easy to setup.
BTW how's the new setup running?
Old Aug 10, 2006 | 09:34 PM
racecar's Avatar
I was concerned about the sensor getting too hot so I put it about 3 feet back from the header collectors.
Old Aug 11, 2006 | 12:16 AM
Spinmonster's Avatar
Mark, It goes on the collector but I made sure not to put it pointing down or moisture will sit around that area and cause corrosion. Just put it in the 4 or 8 o'clock position.
Old Aug 11, 2006 | 12:23 AM
LSX Wizard's Avatar
Yes, the collector or immediately following is best.
Old Aug 11, 2006 | 04:17 PM
Louis's Avatar
Run a dual wideband for both banks if you are going down the deep end and monitoring everything
The merge isnt a bad spot, but that depends on what you are looking to do with it.
