Cylinder Length
Old Aug 16, 2006 | 09:43 AM
rjgto's Avatar
Default Cylinder Length
What are the cylinder lengths on the LS2,L92,& LS7?
Old Aug 16, 2006 | 12:01 PM
427 LS1's Avatar
LS2 apprx. 5.500" If memory serves me right
LS7 5.900" top to bottom of the extended tangs(to accomodate the 4" stroke)
L92 should probably be in line with the LS2 since it uses the shorter stroke.
Old Aug 16, 2006 | 12:32 PM
rjgto's Avatar
Extended tangs? - does anyone have a picture of this?
Thanks
Old Aug 16, 2006 | 01:05 PM
427 LS1's Avatar
I can probably take some pics, basically it's like a C5R block in that regard, the sleeves hang past the parent aluminum material at the bottom to control the piston better at the bottom of the stroke when the piston changes directions. The longer stroke obviously pulls the piston further down the cylider and without the longer cylinders you get problems with ring seal and piston rocking.
Old Aug 16, 2006 | 11:47 PM
Steve - Race Eng's Avatar
LS1TECH Sponsor
Default stock LS7 sleeve
Dave,
I'll save you the time.
Tang extends roughly .200" past the aluminum casting.
LS2 sleeve is 5.5". Your memory is pretty good!
Steve
__________________
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
