ls7 in f-body
Old Sep 14, 2006 | 01:39 PM
TOslowTA's Avatar
Default ls7 in f-body
What all would it consist of to put the ls7 in a 98-02 f-body??
Old Sep 14, 2006 | 01:59 PM
bandit79's Avatar
Do you want to stay dry-sump or go wet-sump?
PAGregSS's Avatar
Your biggest obstacle is going to be the dry sump oiling system. GM Performance Division has had their SS test car at several events this summer that has the LS7 in it. They relocated the battery and a few other things to get the dry sump in.
Old Sep 14, 2006 | 02:01 PM
SSilverSSurfer's Avatar
i believe his name is Jason (KATECH on here) they put one in a camaro, id talk to him
Old Sep 14, 2006 | 02:02 PM
bandit79's Avatar
I think SDPC did one as well.
Old Sep 14, 2006 | 02:08 PM
TOslowTA's Avatar
Just tryin to get a ball park figure on work time + price of required parts....
Already have figured in price of engine and wiring harness...
But what all else is required....
Whats needed to keep dry sump
Whats needed to do away with it
Old Sep 14, 2006 | 02:21 PM
bandit79's Avatar
To keep the dry sump, you will need to move the battery and probably have a custom tank made to go where the battery goes. I am not sure of the cost of the tank. Plus you will need all of the plumbing for it. There are places that have whole dry-sump systems available. To go to wet-sump will be fairly easy, as you would just need to take the LS7 oil pump off of the front and put a LS2 oil pump on. I *think* you can swap all your accessories over from the LS1. You may have issues with the dampener. Then change oil pans to any LS motor pan. Also, the Ls7 is a 58x reluctor motor. Any ls1 car will be 24x. That will be another issue. I think you could probably do it for $2-3k over the price of the motor and harness. If I am wrong somebody correct me please.
Old Sep 14, 2006 | 02:50 PM
Katech_Jason's Avatar
LS1TECH Sponsor
https://ls1tech.com/forums/generation-iv-internal-engine/496186-introducing-world-s-first-ls7-f-body.html
After we get this car in some magazines we will eventually sell it. Keep that in mind.
And before a million people PM me, I don't know what we will be asking for it.
Old Sep 14, 2006 | 03:14 PM
thats it right there, bad ****
