Is this hp correct???
Old Sep 25, 2006 | 05:10 AM
laxmad16's Avatar
Default Is this hp correct???
my friends car is only spitting out 400 hp here is what it has.
2001 WS6 Trans AM
M6
LS6 with forged diamond pistons and ARP rod bolts
Absolute stage 2.5 heads
TTP Equilizer camshaft
400rwhp 375rwtrq N/A on the N20 tune..
it made 416rwhp with 28degrees of timing..
Moser 12 bolt... Eaton HD posi 4:11 gears, extended studs and ALUM cover
Spec stage 3, Pro 5.0 shifter
TNT n20 kit.... 2 bottles... 1 10lb 1 15lb... Dynotune.org bottle heater and digital n20 guage. currently set up for a 150 shot...
SLP headers, SLP loudmouth exuast, ported tb, subframes, LCA's, lid... etc etc.
the car still has full interior and the only thing removed is the A/C.
does this seem like what it should be putting out? i thought ls6's put out 400 stock. at least he told me it was a ls6 block.....also what should the et be with a good driver, no nos= with nos and on/off drag radials thanks
Old Sep 25, 2006 | 06:48 AM
s346k's Avatar
i think this needs to be moved to the internal engine of ls1/6 specific...however..
i feel those numbers are a little on the low side, but not because it is an ls6. ls6 and ls1 are the same cid, only differences in performance upgrades is heads, cam, and intake. ls6 intake came on 01+ f-bod, so that really doesn't matter. but since he has removed the ls6 heads/cam, he now has just another 346 cid engine (same as ls1) so the numbers would be almost identical, should we find an ls1 with the same mods. the hp difference between ls1 and ls6 at the flywheel is ~50hp, due to the better heads/cam. ls6 blocks do not make more power.
i would've guessed ~420-430rwhp with that setup through a 12 bolt m6. as far as track times...there are too many variables to determine his ET, but a shot in the dark would be 12.0-11.8 on a tire, asssuming he actually USES that 12 bolt off the line.
Old Sep 25, 2006 | 06:56 AM
SpaZMaN's Avatar
just because he has lower than expected HP does not mean the power is there....take it to the track for some real numbers, that will show you if its going good.
