L92's Came in 5 Attachment(s) with pictures |
2 Attachment(s) a couple more |
What you putting them on? Bret |
Originally Posted by SStrokerAce What you putting them on? Bret |
I may be wrong, but I do not think LS7 rockers will work. LS7 has 11 degree valve angle, L92 has 15 degree. Will someone correct me if I am wrong? LS7 rocker part # Int. 12579615 Exh. 12579617 L92 rocker part # Int. 12569167 Exh. 10214664 |
1 Attachment(s) I like this shot. Notice how much straiter air flow path is (thanks to offset rockers and raised floor/roof port) compared to LS1,LS2, LS6 cathedral port. The new 2008 Camaro is going to kick some major booty. |
Originally Posted by gollum I may be wrong, but I do not think LS7 rockers will work. LS7 has 11 degree valve angle, L92 has 15 degree. Will someone correct me if I am wrong? LS7 rocker part # Int. 12579615 Exh. 12579617 L92 rocker part # Int. 12569167 Exh. 10214664 |
Maybe I'm wrong, but I am pretty sure LS7 rockers will not work with L92 heads. I have seen a picture of LS7 rockers setting on these L92 heads, the rocker tip overhangs valve stem tip about 1/8 inch if I recall correctly. |
Congrats...I tried to get some postable pics of mine but gave up. We should have mine up and running in about 3 weeks... |
Originally Posted by gollum Maybe I'm wrong, but I am pretty sure LS7 rockers will not work with L92 heads. I have seen a picture of LS7 rockers setting on these L92 heads, the rocker tip overhangs valve stem tip about 1/8 inch if I recall correctly. |
Originally Posted by gollum I like this shot. Notice how much straiter air flow path is (thanks to offset rockers and raised floor/roof port) compared to LS1,LS2, LS6 cathedral port. |
Originally Posted by Beaflag VonRathburg Yeah I was comparing these to a set of 243 castings I have in my room and they look majorly different. The raised roof design looks like it's going to rock. The only thing about them that I see as a slight draw back is the fact that the runners are so large. For the price though they are probably the best thing out now for stroker builds. Now all that's needed is the L76 or carb intake to come out. |
| All times are GMT -5. The time now is 08:42 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
