My LS2 smoking prob
Old Oct 10, 2006 | 12:28 PM
WKMCD's Avatar
Originally Posted by SideStep
Anyone know where this can be purchased...???
Old Oct 10, 2006 | 12:47 PM
stevewix's Avatar
Originally Posted by slt200mph
Myself and many others on here dealt with KJ and his customer service was A+.
KJ was great as well as brian.
BTW I don't know what heads you're using, but the early Darts had some oil drainback issues, maybe this helps GOOD LUCK!
Steve
Old Oct 10, 2006 | 01:35 PM
SideStep's Avatar
Default Valvoline VV850 Racing 10W30 NOT STREET LEGAL Motor Oil
Originally Posted by WKMCD
I haven't even fired mine up yet but soon I will. It will certainly be broken in EXACTLY as described by SDPC.
Ah... good deal... VERY interested in your results...
BTW
I found this... http://www.amazon.com/Valvoline-VV85...8&s=automotive
Old Oct 10, 2006 | 03:07 PM
KRAZY K 2000 TA's Avatar
ive been using Rotella T 15w-40 for a while now can be purchased at walmart 6.32 a gallon
Old Oct 10, 2006 | 04:41 PM
Kounsy's Avatar
Steve
Im using ls6 cnc ported from sdpc. I dont know, it smoked all the time, now its just when the cam is loping or when i let off the gas
Old Oct 10, 2006 | 10:27 PM
Beast96Z's Avatar
...not taking sides in this but there ARE several other 402 owners complaining about smoking and oil usage. I hope this is not one of those "forum" situations where owners/members keep quiet about there problem just to save face... There are a few threads covering this on the Corvette forum also...
I'd like to know how a 402 is diffrent than any other 4" stroke motor? 383, 408, etc... If it is a 402 issue, then that would send the problem towards the block itself, and not the fact that it is a 402. The only smoking issues I've really noticed have all come from SLP 402 owners. Since one of his main smoking points is on decel only, it leads me to believe it is something other than the motor.
Old Oct 22, 2006 | 10:56 PM
mine doesnt smok it just uses oil but now that im using Rotella t it slowed down ,still tyring to figure out a good pcv setup for my car,i have the husky catch can setup from home depot it always has oil in it.
Old Oct 22, 2006 | 11:15 PM
AppleMac's Avatar
Originally Posted by See5
Two things:
Have you sealed your rocker bolts?
My 402 (SDPC) sucks oil into intake from valley cover vent. A catch can will help catch it, not stop it.
In my case I think the motor is fine, rather these two things are just more of an issue with more displacement and LS designed venting.
Can you elaborate on this?
I just tq'ed my rockers to 18 ft/lbs and forgotta about it... You have to seal them?
I have ETP 225 heads if that makes a difference...
Old Oct 23, 2006 | 08:59 AM
Scalpel's Avatar
Do a formal leakdown test. It'll give you the most likely cause(s).
Old Oct 23, 2006 | 05:29 PM
olddog's Avatar
Lots of info here - - I won't touch the oil brand as it is a pet research project of mine but you stated that you were running a breather. If you are running a breather then you should NOT be running the PCV.
We pull and port many manifolds and are astonished at the oil in the galley from the PCV - - I used to use about a qt every 1500 and now use NONE at all.
Try plugging up the pcv first and where is your breather - - should be on the oil fill for proper size to evacuate pressure.
Good luck!!
Old Oct 24, 2006 | 08:12 AM
slt200mph's Avatar
I run a LS6 valley cover with LS6 PVC and a breather in the oil fill with custom valve covers and have no oil consumption problems...
Old Oct 24, 2006 | 04:32 PM
  #32
Kounsy's Avatar
Good luck!!
im not running a pcv right now.
i was thinking custom valve covers, and run 2 breathers
Old Dec 14, 2006 | 12:17 PM
  #33
SideStep's Avatar
Any more information on this thread???
Old Dec 14, 2006 | 12:40 PM
  #34
TNTramair's Avatar
subscribing.....
Old Dec 14, 2006 | 01:01 PM
  #35
WKMCD's Avatar
I've got about 600 miles on my ls2 402 now. It's not smoking at all and I can't detect any oil usage. I'm using Rotella and added the can of GM anti-scuff stuff that SDPC provided. I'm changing th oil this weekend. I'm either going to use Rotella again or Valvoline Racing (not for street) oil. It also has ZDDP in it. SDPC recommended not running Synthetic for the first 10K miles.
I tee'd the valve cover vents together and run that to the air bridge. I'm running a breather off the valley pan. I still haven't determined the final configuration for venting. It will involve a catch can or two.
Old Dec 14, 2006 | 02:44 PM
  #36
MSGHUFF's Avatar
No smoking on mine and it gets a daily beating.....using the factory pvc with catch can
Old Dec 15, 2006 | 06:33 AM
  #37
SideStep's Avatar
Hey what is the dish on your pistons???
Old Dec 15, 2006 | 09:32 AM
  #38
MSGHUFF's Avatar
-14cc I didnt plan on having that much but the heads were already milled so I needed it to get my DCR reasonable..
