L76 Fuel Rails
Old Oct 10, 2006 | 07:28 PM
WKMCD's Avatar
Default L76 Fuel Rails
We're getting ready to assemble and install the 402 using L92 heads and L76 intake. Any thoughts as to what fuel rails I'll need with 42lb green top injectors?
Old Oct 10, 2006 | 07:38 PM
Rock_Daddy's Avatar
Did your L76 intake come with rails and injectors? If so did you have any guess to what they support? I have a 415 L92 based motor and all I have so far is the stock truck intake, rails and injectors. I wounder if they even worth trying or should I jsut start making the same move you are.
I have some fab work left before fireing it so Im not in too much of a hurry yet.
Old Oct 10, 2006 | 07:47 PM
BLKWS6's Avatar
just looking at pics of the intake it looks like the LS2 rails would work with it. has anybody tried those yet?
or now that i think about it more...the LS7 rails will work. same intake except for the ports....basically
Old Oct 10, 2006 | 08:22 PM
See5's Avatar
If you use a LS2 rail you will end up with injector fitment issues. When I was running a LS2 Intake I cut a LS1 rail and made hose crossover. Worked great although the LS2 intake was a dud.
Old Oct 10, 2006 | 08:24 PM
WKMCD's Avatar
Just a bare L76 intake. We're playing it by ear on this build but it should be very interesting.
Old Oct 11, 2006 | 11:53 AM
yardboy's Avatar
What cam, springs and rockers are you going to use?
