Should I get an LS2?
Also you won't have to worry about having to convert the timing wheel from 58x to 24x if you go with a 402 that has the 24x on the crank.
but if you go with that much motor you will definitely want to have the driveline to back it up.
Speaking of crate motors has anyone been over to GM's page and seen the new LS2 carb crate motor (440hp/418tq)...
