LS1 -> LS2 Hows this look?
Knock Sensor Adapter (Ordered from Katech)
Cam Sensor Adapter (Ordered from Katech)
KAT-A4757 Injector adapter harness kit (Ordered from Katech)
KAT-4751 LS2 / LS7 MAP extension harness (Ordered from Katech)
CAMARO LS1 OIL PAN (From LS1)
Holley 90MM Throttle Body (Ordering)
Is this all ill need? Anyone know of anything ive left out?
I did have one question, everyone says the accesories bolt right up.
http://gmhightechperformance.com/fea...p_ls2_01_z.jpg
that image has a completly different config, do I just go about installing it all like on the LS1? Also will an LS1 underdrive pulley work? I dont want to rerun the belts and accesory drive without checking, cuz it might make things turn at different rpms than they are supposed to or something i guess lol. Also whos got the best price on the Holley Throttle Body (90MM).
Thanks,
John
Thanks,
John
I have been thinking about the same swap. I noticed SLP sells a LS2 strocker short block and it comes with everything needed to install it into an LS1 4th gen. You could try getting their parts list or calling them. It might answer your questions about the accessories.
Thanks JA
