L92 heads/L76 intake
They share the same part number fuel rail...wouldnt the injector be the same height?
Will SVO 42s and aftermarket fuel rails such as the FAST fit on the L76 intake?
L76 intake (complete) - LS2 fuel rails, LS7 fuel injectors, and 90mm throttle body (<-useless in a F-body as its a fly-by-wire design).
In order to run the injectors will require adapter harnesses on each injector since the LS7 injectors are an EV6 type injector just as the LS2 injectors are, while the LS1 injector is an EV1 type injector.
Now if the bosses/holes for the injectors are bigger on the intake like the LS2/LS7 and I wanted to use an aftermarket LS1 injector such as the SVO 42, I would need the Katech KAT-A4096 LS2 adapter kit.
http://www.katechengines.com/street_...tail.php?id=35
I think with the kit above, I should be able to run aftermarket fuel rails as well. Now if the LS7 injectors support the power I plan to make (600 rwhp), then I'll just leave the complete intake kit as is, minus the throttle body, and just buy the adapter harnesses for the injectors.
Does all of this sound right?
http://www.thunderracing.com/catalog...d=380&pcid=163
I need to verify what size injectors come with the L76 intake kit because that will determine if they are going to be sufficient for my motor or not. Are they LS7 injectors, if so, then they are 42 lbs. Either way, it doesn't matter what the name is, I just need to know size. They're obviously an EV6 type injector because they require adapter harnesses because the LS1 harnesses are for a EV1 type plug.
My Nick William 90mm throttle body will work, so that's a big relief.
I also need to verify if they bosses/holes for the injectors are bigger than the LS1 intake manifold as they are on the LS1/LS7 intake manifold, that way I know that I need the adapter kit from Katech.
Lastly, will aftermarket rails work with this intake?
Come to think of it, couldn't I just buy the intake bare, use my throttle body, aftermarket fuel rails, and SVO 42s and if things don't fit, I can modify as needed. The only thing that could possibly not fit is the injectors because the bosses/holes for the injectors may bigger in the L76 manifold than the LS1, which that's no big deal because Katech has an adapter kit for it. Then if the mounting stuff doesn't fit or isn't in the right location, that I'm sure can be modified. Just gota have a little fabbing skills.
The injectors are stated as 40lb on the L92, and 42lb on the LS7. I imagine they are the same, with the discrepancy due to a small rail pressure difference for testing. 42lb is easily within a tolerable margin for setting your rail pressure to attain a desired flow rate. If these injectors, rails, and intake work for you, then the complete package will probably be cheaper than sourcing things separately. What do you plan to gain with aftermarket rails and SVO injectors? If you already have aftermarket rails, I'll bet you'll be able to sell them and cover some of the cost of this package.
I'll examine the injectors tonight for a part number to close the question
Edit: If you're sitting at 575-625rwhp and run 50-55psi rail pressure, then you may be OK with the ones that come with the kit. If I were making that decision, I'd get the kit and look at the resulting injector duty cycles. The price is so much better than the alternatives I think it'd be dumb not to give it a shot unless it's obvious you're looking at the wrong ones.
I guess I could always buy the kit, if they aren't enough (checking duty cycle), then I could always sell them.
I believe the stock LS1 fuel pressure is around 52 lbs. I don't know of any way to increase fuel pressure other than a pump. I could install a regulator, but that would only reduce the pressure, or am I completely wrong?
>PA6< 920
0280128021
12576341
The underlined part is faint, tiny, and right under the connector so I was reading upside down with a "mirror" aka the tiny end of the handle of my fingernail clippers.
Edit: It's these:
http://www.sdpc2000.com/search.asp?s...6341&doquery=1
