PCV Setup (LS1 Conversion)
Old Nov 9, 2006 | 01:12 PM
2KThunder's Avatar
Default PCV Setup (LS1 Conversion)
Im converting from an LS1 to and LS2 (full engine). The LS1 PCV setup has a vacuum line going from valve cover to valve cover. The LS2 Valve Cover has a male port on the rear of the drivers, none in the passenger. What goes into that back male connection on an LS6/LS2 setup? Is it just vacuum spliced from the brake booster? TIA,
John
