What to do with PCV system on a L92 drag application?
Old Nov 17, 2006 | 11:43 AM
ls1408cp's Avatar
Originally Posted by matt346ls1
You have to run a baffle so oil does not fling continously into the line to the pump and regulate the vacuum so you don't pull too much. You should probably not run a race vacuum pump for street driving unless you can only pull a few lbs and then turn it up at the track.
Matt
any good pics of baffles would be great
