ls1 or ls2
Old Nov 17, 2006 | 07:59 PM
nova69's Avatar
Default ls1 or ls2
LS1 or LS2 or LS6. what is a 2006 5.3? Ok, just want to make sure i understand what i need. i have a Lh6,5.3 with dod. i want to put a ls6 intake on it and a cam swap, i read that the heads on this engine are the ls6 type. casting on the heads are #799. so i need to change the acc, brackets im going to use f-body for that. also the intake and t/b but would i use everything fuel rail, injecters? for the cam swap would i use ls1 valve train or ls6? lifters, pushrods springs thanks for any input p.s im going to disable the dod
