PCV upgrade??
Old Nov 20, 2006 | 07:05 PM
03 BUSA's Avatar
Default PCV upgrade??
Is it Ok to remove factory setup and just plug off Throttle body port and install a K&N type valve cover filter on each side? Thought I read somewhere this was not the way this should be done but could not find in the search. Thanks for the help.
Old Nov 20, 2006 | 07:33 PM
Steve01SS's Avatar
Yes... you basically do it old school. Cap off all PCV ports and run a breather where the oil cap goes. You really only need to run one on one side...
Old Nov 20, 2006 | 07:57 PM
03 BUSA's Avatar
Thanks man.
