LS2 into Fbody, shimming oil pan needed?
Old Nov 26, 2006 | 06:39 PM
2KThunder's Avatar
Default LS2 into Fbody, shimming oil pan needed?
Does the f-body windage tray needs to be shimmed with a stock LS2? Ive read it does on the 4XX cube Ls2s but am I correct in assuming it doesnt need to be shimmed in the 6.0 stock form? Thanks,
John
Old Nov 26, 2006 | 07:09 PM
Randy WS6's Avatar
I had to shim my windage tray in my LS2 418cid. but it was because i put a 4.100" stroke crank & 6.125 rods and had to shim the tray to clear the rod bolts . But i would think you would haft to shim any LS style block with a longer stroke ,maybe not with a 4.00" but you will with any thing bigger
Old Nov 26, 2006 | 08:09 PM
Sam88Gta1's Avatar
John
No it does not..I have a stock stroke ls2 with 6.125 Eagle rods w/upgraded L19 rod bolts and it clears fine.They hang off the crank .0100 or more then the stock rod.
Old Nov 26, 2006 | 10:25 PM
Beast96Z's Avatar
Not on the stock LS2. Anything with a stroker crank is likley to need spacing.
