my 60lb er's in l76 intake?
does an ls1 fuel rail setup bolt up to the l76 or do i have to buy the complete intake if im shooting for a 416 in my 02 camaro?
Katech has developed kits to adapt the Gen 3 LS1/LS6 style injector into the LS2 or LS7
KAT-A4674 LS7 adapter kit $24.99
If you have the LS1 style fuel rails that have a return line then you may have to do some hand fab'n to get them to work with the L76 manifold. The L76's fuel rails do not have a return line (just like the LS2 and LS7)
We didn't need an adapter kit for my car...... a little "work" and we got my LS1 fuel rails on my L76 intake
so let me get this straight. my fuel system is returnless. so if i get the stripped l76 manifold, ls2 stock rails, rail spacers, and different orings im good to go? will the ls2 rail system hook up to my oem ls1 fuel lines?
do the ls2 fuel rails support more flow or are they stricking tabbed different for different mounting locations?
LS1 fuel rail mounting tabs are in slightly different locations than the LS2 rails, which is what the L76 intake kit comes with. I verified this by placing the LS2 rails on a FAST 90mm intake. They don't line up, but anyone with some fabbing skills can fix this.
If you want to use your Motron injectors, you'll need to either find you a set of o-rings that will seal the injectors snug into the intake or buy Katech's adapter kit. If you want to reuse your LS1 fuel rails, then you'll need to modify your fuel rail mounting tabs because for one they aren't going to line up with the bolt holes in the intake.
http://www.thunderracing.com/catalog...vid=3&pcid=163
-Geoff
