Gen IV truck engines??
So wouldn't that mean any of the intakes off the 4.8/5.3/6.0/6.2 are all common on the new body style 07's Suv and truck V-8's.
So any intake off the engine would fit the L92 heads right?
The valve size/layout of the L92/L76 heads only allow it's use on the 6.0 and 6.2 (and larger bore'd) engines. Only the 6.0L and 6.2L engines are using the L92/L76 cylinder heads, therefore the L92 and/or L76 intakes only fit those heads.
Any one know???
The Vortec 6.0L and 6.2L engines offer a significant power level increase compared with previous premium engines, with much of the newfound power coming from high-flow aluminum cylinder heads. The heads are based on the racing-derived cylinder heads of the Corvette Z06’s LS7 7.0L engine, including a unique inlet port shape and offset rocker arm design. Airflow of the heads is supported by large 55-mm-diameter intake valves and 40.4-mm-diamter exhaust valves.
“The heads use the high-performance technology of the Corvette’s LS7 to build efficient power in truck engines,” said Meagher.
Vortec 4.8L and 5.3L engines also have high-flow, Corvette-derived heads. They are based on the previous-generation Corvette Z06’s LS6 engine’s cylinder heads and have flow characteristics commensurate with the engines’ airflow-to-displacement needs. All the Gen IV Vortec engine variants use the same efficient ignition coil packs of the LS2 to light off the air/fuel mixtures that are drawn through the heads.
Looks like the 4.8/5.3 Gen IV engine use a Gen III Z06 based head so I guess their Intakes won't work with the L92 heads! Unless someone has actually seen them.
2007 GMT-900 Information
http://www.gminsidenews.com/forums/s...16&postcount=4
GMInsideNews Forums - View Single Post - 2007 GMT-900 Information
