ls2 will not fire up, any suggestions>?
i am sure the above switcheroo would cause it to not fire up correct?? car is at parents place so i cant test my theory until wednesday
would that cause no spark as well?
Picture:
http://www.hptuners.com/forum/attach...7&d=1165783888
more discussion:
http://www.hptuners.com/forum/showth...ght=cam+sensor
Picture:
more discussion:
i think that is just on the racetronix harness isnt it?? or is it on the katech one as well?
It turned out that i had the crank sensor and the oil level sensor switched around, so i swapped those today, went to turn on the key, and the guages didnt light up and when i switched the key nothing! I was like WTF it cranked yesterday, so i called JAMES, the man @ lindsay, him and ewillard3 helped me out over the phone, they suggested to check the grounds. So we got off the phone i did that and still nothing.
So i swapped around some of the 4 relay switches in the main box and finally got some dash lights. Cranked it up and my god it started!!!!
Might have some bad gas in the tank though not sure, but did get it off the jack stands and it did move under its own power!!!!! I was so pumped I was like a kid on christmas!
here is the vid
nothing special but here it is running
http://sio.midco.net/dvandentop5/MOV02766.MPG
and here she is back on the ground after being in the air since like August!
the front end is tore off due to having to remove bumper cover to install headlights in the V's, this was a repairable car and i had to install a new ls2 in it. now it runs and I am happy
