Drive by wire throttle movement
Old Dec 18, 2006 | 11:39 PM
motorhead0922's Avatar
Default Drive by wire throttle movement
As a preliminary check to see if things are hooked up right, does the throttle plate move when the gas pedal is depressed when the ignition is on but the engine is not started?
This is on an LH6 out of an 05 Envoy.
Thanks in advance.
Old Dec 19, 2006 | 12:00 PM
sonicbaloo's Avatar
I have removed the intake and turned the key to the on position with the motor off and the blade does move. Np problems with anything as long as the MAF stays plugged in.
Chad
Old Dec 19, 2006 | 01:03 PM
You're awesome Chad. Thanks!
