motor mount bolts
Old Dec 22, 2006 | 09:48 PM
bad intentions's Avatar
Default motor mount bolts
does anyone know the size and length of the motor mount bolts for a 2000 camaro i need the all eight plus the two that hold the motor to the frame...
Old Dec 22, 2006 | 10:51 PM
Ferocity02's Avatar
I believe the bolts that hold the engine mounts to the block are M10. The two top ones are special, they have a little stud sticking out that holds a heat sheild on the driver's side. Not necessary though. The two engine mount bolts are big, M14 maybe. I just put them in you should have asked this earlier lol. The dealership should be able to tell you the exact dimensions.
