Sleeved LS2 v. LS7
When was your block machined? I don't recall doing business directly with you nor has anyone called me about a problem with an MID block tht I have machined in years. I've got hundreds of wet sleeved blocks running out there, many with boost.
There are at times problems with some blocks, aftermarket sleeved or not. Attached are photos of two factory C5R blocks with sleeves that failed running normally aspirated. The second was not caught in time before the sleeve actually broke. That one is currently at my shop for repair.
I've repaired a couple of LS7 blocks with the same problem.
Steve
Hell, I had a customers MID block that didnt make to 3k miles at 10 psi boost before pissing into the coolant. It was also done Via Steve at Race engines inc no less.
The motor has been sporting an LS7 block for the last 15k or so with no issues.
Dave
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
Dave
Steve
If there is a problem with a Darton product, feel free to call me. The above mentioned engine that was done by another shop was repaired free of charge by Darton and myself for the customer even though we had nothing to do with the problem.
The MID sleeve installations have held over 60 lbs. of boost in import applications. The Ecotec was run at over 45 pounds of boost without problems. I have my own design sleeves for the Viper engines. I have a customer with a boosted engine, 15 pounds (930 hp to the rear wheels) running on the street for over three years now.
As I mentioned in my last thread, there are problems at times with products. No one can be 100% perfect.
Steve
Dave
Steve Demirjian
Oceanside, Ca.
760-630-0450
Continue to get your company's name out there. I sure would have ordered my engine from you instead of Scoggin Dickey, had I known about your company back in November. It sounds like you have the experience and quality that everyone is looking for.
