mystery block?
Old Dec 27, 2006 | 03:45 PM
Black5.0's Avatar
Default mystery block?
the number 12568952 is stamped on the back of the block, right underneath the passenger side cyl. head. i beleive it is an ls2 but i'm not to sure, i know it is stamped "GM" and "6.0L" on the back of the block, and it is aluminum. i was just wondering if anyone out there can confirm it, or if you'll know of a site where i can cross reference that number.
Old Dec 27, 2006 | 04:07 PM
NO-OPTION-2002's Avatar
That is a GM LS2 aluminum 6.0 liter block.
Part # is 12568950 (2 #'s less than casting #)
Old Dec 27, 2006 | 07:00 PM
Black5.0's Avatar
Thanks for the help. what would i have to do so stuff that motor in a '98 Z28?
Old Dec 27, 2006 | 07:12 PM
Beast96Z's Avatar
Buy a LS2 conversion kit from SDPC. You may also have to change the crank from your 98' into that block because of the reluctor wheel signal, or have the reluctor wheel changed out to the appropriate LS1 signal.
Old Dec 27, 2006 | 10:05 PM
DoesSpeedTurnUon's Avatar
The kit is $299 from SDPC, and i believe you only have to change the reluctor wheel if you're going in a 2005 or newer.
