Solid Lifter
I previosuly had the Comps back when they had too large an oiling hole. had the oil hole been the correct size i would have preffered the comps. They have a link bar connecting the two lifters to keep the straight. And they were very very light and had a short body. . I just called Comp and they now have thier newly redesigned lifter PN 8956-16. I havent even seen a pic of them yet.
I think most serious racers with no budget use Jesel though. But I belive they are pricey.
The stock lifter trays use flat spot on either end to keep the lifter oriented correctly.
Lifters that do not use the stock lifter trays must use some other device to keep the lifters oriented correctly...most use a link bar between the two lifters on that cylinder. that will keep them from turning during engine operation. The flat rollor riding on the flat cam alone is not enough to ensure the lifters orientation. Especially on a solid roller where there will be loss of contact between the two surfaces. Any slight turning would tear up that cam surface in a hurry since the dge of the lifter roller would impact the cam.
BTW...Ill have a new set of the Comps here in a few days. Ill post them up when I get them.
So if I already have a set of new lifter trays for my new motor, should I stick with the regular Morel hydraulic lifters, or do away with the trays and use the new Morel lifters due out in February? You could definately do a cam swap without removing the heads and there are 0 worries of droping a lifter in the block.
Otherwise, the Crower High Pin Oilers (HIPPO) are very good on the street. The current Morels do not provide this, but the revised ones will for the LS1.
