Need expert l92 help
The set up:
iron 408
4.030 bore
4 inch stroke
6.125 rods
Mahle -12 cc pistons
LPE GT-11 215/231 and .631/.644 118LSA
PRC stage 2.5 heads (like 305cfm flow)
I want to run L92 heads, but I don't know if the valves will clear the pistons with the cam I have. Is any one else running the L92's with these mahle pistons?
Then, if I shouldn't have any clearance issues, what would happen if i went with a more aggressive cam in the future. Would I be better to keep the heads I have or stick with the L92's.
See where I'm going with this.
I think one of the tricks to the L92 head is going to be opening the intake valve late. That is just a hunch though, based on talking to old time gear heads locally who refer to it as a "lazy port" head.
-Geoff
I plan on running a TRAK cam, .040 gaskets, and the heads will be shaved .030, Manley pistons (.010 over the deck). The max intake valve the pistons will accept is 2.08 and the L92 has 2.16 intakes (and they are offset towards the center.
I hope that I have enough clearance as it is , but if not at least I have a plan.
Bob K.
The set up:
iron 408
4.030 bore
4 inch stroke
6.125 rods
I just put together my 408 with a comp 231/235 110+0 LSK, -9cc diamond pistons, 65cc chamber, .041 head gasket with REV 2.160 I and 1.6 E valves and had plenty of P/V clearance.
