L76/C5 Question
Old Jan 20, 2007 | 01:19 PM
VortechC5's Avatar
Default L76/C5 Question
I am researching building a 418 or 427 with the Livernois L92 heads. This means that I would use the L76 intake. I know that I can buy an adaptor harness so that the 90mm drive by wire TB will work with my C5. Will my stock C5 fuel line hook right up to the fuel rail that is provided with the L76? I'd like to use the complete intake/injectors/TB/fuel rails as delivered if at all possible.
Old Jan 20, 2007 | 02:54 PM
WKMCD's Avatar
You'll need to run LS2 fuel rails or aftermarket. I chose the latter.
Old Jan 20, 2007 | 03:36 PM
VortechC5's Avatar
Thanks. Will the LS2 fuel rails work with the injectors that come with the L76? Do I need any kind spacers?
I just remembered that the connectors are different on the injectors as compared to the LS1 style injectors aren't they?
Maybe I need a bare L76 intake, a 90mm TB, and use LS1 injectors and my stock fuel rails?
Old Jan 20, 2007 | 07:45 PM
See5's Avatar
I suspect you would be better off witout the L76 injectors as they will likely be too small. You can use the old or new style injectors by modifying the rail. If you use the new style you will have to change electircal connectors to the LS2 style.
