Optimal 408 Set Up?
Old Jan 21, 2007 | 07:12 AM
97Rob's Avatar
Default Optimal 408 Set Up?
My 408 is back under the wrench . The engine was originally built loose by the previous owner. The guy that works on it now discovered the piston cylinder wall clearance was a little out of spec. Thinking about going .040 over and new pistons. Had a cam back out and a lifter turn, which caused us to have to replace the cam, lifters, timing chain, and crank. Thought it would be a good time to go .040 over and get new pistons. If I'm going to do all of this I want to do it right and get the most out of it. Looking for opinions on best possible set up. Below is a list of parts that goes w/ set up. The car dynoed 502 RWHP and 485 LBS torque. I'd like to be around 540-550 RWHP and 500 + in the lower end torque. My last set up made its power fast at lower RPM'S w/ a custom ground cam by Bauer Racing. I like drive ability. Those pojections may be a little ambitious, but lets see how it goes. Also will be spraying a nice shoot of nitrous down the road.
-6 litter iron block
-Dart 225 slightly ported on the exhaust
-90 Fast intake
-90 LS6 throttle body, or Nick Williams
-Kooks long tubes
-no cats
-Zo6 cat backs
-Varram Intake
-did have 12.3:1 compression 100 octane
I feel like I've left something out. This will get it started anyway.
Rob Edwards
Old Jan 21, 2007 | 11:03 AM
dame's Avatar
If it were my setup.... I'd sell the FAST stuff, as well as the dart heads.......... I'd call up TEA and have then send me a set of L92's with Brian Tooley's famous "nitrous exhaust port", order a L76 intake from SDPC.... then I'd Fax over the flow sheet from the heads along with a brief description of what i was looking for out of the car to synergy motorsports to have me a cam custom ground for me
Good luck on your rebuild and keep us posted
Old Jan 21, 2007 | 11:51 AM
97Rob's Avatar
Thanks for the intrest and input. I'll keep it updated.
Old Jan 21, 2007 | 07:49 PM
98Z28CobraKiller's Avatar
Restricted User
There's already a famous "nitrous exhaust port" option for the L92's? I haven't even seen any stellar numbers on the L92 or the LS7 head/intake combo that haven't already been hit with the FAST 90/90 + premium cathedral port heads. If you didn't already have the FAST it would be a different story. Then you are talking budget.
