427/L92/L76 combo suggestions...
Old Jan 29, 2007 | 07:43 PM
wavrdr's Avatar
Default 427/L92/L76 combo suggestions...
Hey guys, I've done quite a bit of reading over the past few days as I'm heading into large cube territory and there are a few things I'm not so sure about....
What head bolts does the L92/LS7 combo require?
Should I look into milled L92 heads?
Are roller rockers a "wise" mod for proper geometry?
What cam would everyone suggest for a "healthy" setup and whom to purchase from?
If there is anything that anyone can think of I'd greatly appreciate your insight!
Alan
Old Jan 29, 2007 | 09:38 PM
Mizfit MotorSports's Avatar
I would suggest heads studs..as far as milling and cam that should and will depend on if the heads are as cast out of the box or ported heads. The compression will also be a factor when you are considering milling heads and picking a cam. I would also suggest Gm racing lifters and harlan upgrade for the rockers. Just some of the stuff we are doing on ours.
Old Jan 30, 2007 | 04:28 PM
wavrdr's Avatar
I was unaware that there was a rocker availablefor the L92 aside from the stockers....Do you have a PN # you could provide me with?
TIA!
Old Jan 30, 2007 | 05:58 PM
VortechC5's Avatar
I think that he means the Harlan upgrade for the stock rocker trunion.
Old Jan 30, 2007 | 06:31 PM
wavrdr's Avatar
Gotcha....
Old Jan 31, 2007 | 05:13 PM
Cop Car's Avatar
my suggestion is to use LS7 heads
