Stock or Harland sharp?
Old Jan 30, 2007 | 10:46 AM
ls2formula's Avatar
Default Stock or Harland sharp?
I know everyone like stock rockers but what about with this cam
intake exhaust
247 251
.656 .660
I have a brand new set of Harlands just dont know if I should use them because everything I have read says they are heavier.
Old Jan 30, 2007 | 11:42 AM
Nasty N8's Avatar
Harland Sahrp rockers are actually lighter than the stockers. The roller tip is slightly heavier(but not very much) which is a givin. If your valve train setup is correct you will have absolutly no issues with the Harlands. If you are really worried about it we offer a Harland Stock rocker mod that replaces the center bearings inthe stockers with the same heavy duty rollers as the aluminum full roller rockers. $250
Nate
Old Jan 31, 2007 | 09:14 AM
ZLEEPER's Avatar
Nate,
Do you have the L92 Rockers with the Harlan Sharp mod?
