ordered a cam for my LS2
i already have a volant intake, TNT 150 shot, solid DS, performabuilt trans w/ 3500 stall and stock 3.46 rear end gears, along with kooks 1 7/8th primary 3 in collector headers, and magnaflow catback
my question is, will that cam work good with my setup? its their nitrous/turbo cam, so it will work with my nitrous, but how good? should i see a hp increase across the board, or just a bigger jump up top?
also, i was thinking about getting it with a 112LSA, but how would that affect the cam and also the power? i kinda want that lopey sound/idle, but was told it would be easier to pass emissions with the 114LSA. out here in AZ it seems that you can pass a smog check pretty easy. since the car is OBD2, all they do is hook up a scan gauge and see if theres any codes. if there isnt, you pass (my friend had a custom turbo on his mazda3 hatch a few years back and passed).
im just wanting to know cause the order hasnt shipped yet, and they are waiting on those cams to come in (either mon or tues), so if i wanna change it and upgrade to a different grind or a custom grind i better do it now. thanks
Bret
p.s. sorry I had to say it, the old lady is throwing a fit in the other room and this is my salvation at the moment.
My friend used the same cam but on a 117 lsa on his TBSS with a 150 shot and I think on the spray he put down 498 to the tires.
Cam discussions are a pain in the *** though. Everyone has different oppinions and seems to disagree with what the other guy says. My advice is to call up your tuner, or a reputable cam guy and see what they think.
Oh, and I might add (now that I notice who posted up before me), if you want the best cam for the job....cancel your order and have Bret design one for you. He's the man.
the other thing is, i wouldnt mind more lift, but i dont know what would work with my setup. thunder also has this one 230/236 .592/.602 112 LSA but what would i gain/lose over the other cam? im asking for advise cause i dont know anything about cams.
also, i dynoed 487/460 on the bottle and 320/320 off.
more lift is better on these. either way, you'll gain 30rwhp at minimum.
